Hue/Saturation/Value Node¶
The Hue/Saturation/Value Node applies a color transformation in the HSV Color Model.
Inputs (Inputs)¶
- Image/Color
Standard color input (Standaard kleurinput).
- Hue (Tint)
The hue rotation offset, from 0 (-180°) to 1 (+180°). Note that 0 and 1 have the same result.
- Saturation (Verzadiging)
A value of 0 removes color from the image, making it black-and-white. A value greater than 1.0 increases saturation.
- Value (Waarde)
The value shift. 0 makes the color black, 1 keeps it the same, and higher values make it brighter.
- Factor (Factor)
The amount of influence the node exerts on the image.
Outputs (Outputs)¶
- Image/Color
Standard color output (Standaard Kleurouput).
Hue/Saturation Tips¶
Some things to keep in mind that might help you use this node better:
- Hues are laid out on a circle
If you apply a Hue offset of 1 (+180°) to a blue image, you get the diametrically opposite color, which is yellow. If you apply a Hue offset of 1 to that yellow image, you get blue again.
- Grayscale images have no hue
Trying to change the Hue or Saturation of a grayscale image has no effect. You can only brighten or darken it by adjusting the Value. To add color, use the Mix node instead.
- Changing the effect over time
The different values can be animated using a Time Curve node or by setting keyframes.
HSV Example¶
A basic example.¶
An example of using the Factor input for masking.¶
