Is Edge Manifold Node
Is Edge Manifold Node.
The Is Edge Manifold node outputs a boolean value indicating whether each edge in a mesh is manifold. A manifold edge is shared by exactly two faces and has consistent face normals, meaning it is part of a continuous surface without gaps or branching edges.
This node is useful for detecting mesh topology issues or isolating boundary or non-manifold edges.
Inputs (Inputs)
Deze node heeft geen invoer.
Outputs (Outputs)
Manifold
Boolean value that indicates whether each edge is manifold. True if the edge is shared by exactly two faces; false otherwise (for example, if the edge belongs to one face, more than two faces, or no faces at all).
