Spline Length Node
Spline Length node.
The Spline Length node outputs the total length of each spline, as a distance, or a number of points. This is different than the Curve Length node, which adds up the total length for all of the curve’s splines.
The output values correspond to the spline domain, but the node can be used to output a value for every curve control point as well.
Inputs (Inputs)
Deze node heeft geen invoer.
Outputs (Outputs)
Length (Lengte)
The length of each spline.
Point Count
The number of control points in each spline.
