NURBS Weight Node¶
The NURBS Weight node outputs the NURBS weight of each control point in a NURBS curve.
NURBS weights influence how strongly each control point affects the shape of the curve. Higher weights pull the curve closer to the corresponding control point.
Notitie
This node reads the built-in nurbs_weight attribute. The same values
can be accessed, modified, or transferred using nodes that operate on attributes.
Inputs (Inputs)¶
Deze node heeft geen invoer.
Outputs (Outputs)¶
- Weight (Gewicht)
The NURBS weight of each control point.
For geometry that is not a NURBS curve, the output is zero.
