Edge Paths to Curves Node¶
![Edge Paths to Curves Node.](../../../../_images/node-types_GeometryNodeEdgePathsToCurves.webp)
The Edge Paths to Curves node output curves that follow paths across mesh edges.
See also
This node is meant to use the output of the Shortest Edge Paths Node. It is similar to the Edge Paths to Selection Node, but it creates a curve that follow each path, rather than a selection of every visited edge.
Inputs¶
- Mesh
Standard mesh input.
- Start Vertices
A selection of the vertices to start at when traveling along the next vertex indices.
- Next Vertex Index
Describes the path to follow at every vertex.
Properties¶
This node has no properties.
Outputs¶
- Mesh
Standard curves output.
