Mesh to Volume Node
Mesh to Volume node.
The Mesh to Volume node creates a fog volumes based on the shape of a mesh. The volume is created with a grid of the name "density".
Inputs
Mesh
Standard Mesh input.
Density
Value of voxels inside the generated fog volume.
Voxel Amount
Specify the approximate number of voxels along the diagonal.
Voxel Size
Specify the voxel side length.
Interior Band Width
The maximum distance of the included voxels to the surface on the inside of the mesh.
Properties
Resolution
How the voxel size is specified.
Amount:
Size:
Specify the voxel side length. It is recommended to be careful when tweaking this value, because small changes can have a large effect on the processing time.
Outputs
Volume
The generated volume grid.
