Mesh to Points Node¶
The Mesh to Points node generates a point cloud from a mesh.
Inputs¶
- Mesh
Standard Mesh input.
- Selection
The meshes used to generate a point cloud.
- Position
Positions of generated points. By default, this input is the same as if the Position Node was connected.
- Radius
Radii of generated points.
Properties¶
- Mode
- Vertices:
Points are generated for each vertex.
- Edges:
Points are generated for each edge, at the middle of each edge, by default.
- Faces:
Points are generated for each face, at the average of all of each face’s vertices, by default.
- Corners:
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Outputs¶
- Points
Generated point cloud.
