Face Corner Angle Node
Face Corner Angle Node.
The Face Corner Angle node outputs geometric information about the angle at each face corner of a mesh. It can be used to analyze the shape of polygons, detect sharp corners, or create procedural effects based on corner geometry.
Ingressi
Uscite
Corner Angle
The internal angle at each face corner, measured in radians. For example, a right angle returns approximately 1.571.
Bisector
A normalized vector pointing along the bisector of the corner angle, halfway between the directions of the two connected edges.
