Combine Spherical Node¶
The Combine Spherical node converts spherical coordinates (R, Φ, Θ) into a Cartesian vector (X, Y, Z). It is the inverse of the Separate Spherical node.
Spherical coordinates represent a point in 3D space by its distance from the origin, horizontal rotation, and vertical inclination, which can be useful for constructing radial or rotational patterns and generating coordinates on a sphere.
Ingressi¶
- R
The radial distance from the origin.
- Phi
The azimuthal angle (horizontal rotation) around the Z axis.
- Theta
The polar angle (vertical inclination) from the ground plane.
Uscite¶
- Vector
The resulting Cartesian vector corresponding to the input spherical coordinates.
