Custom Effector¶
Create a custom effector for use in a simulation. This can be used to modify geometry or the simulation world as a whole. A closure must be provided which is evaluated by the simulation at some point during the time step update, depending on the Stage.
Ingressi¶
- Tipo
Defines the data the effector is applied to and the closure signature used.
- Geometria:
Apply the effector to all geometries in the simulation world that match the Filter tags.
- Mondo:
Apply the effector to the simulation world as a whole.
- Stage
Stage during the simulation update at which the effector is executed.
- Default:
Executed at the end of each time step (same as Post-Solver).
- Pre-Simulation:
Executed at the beginning of each frame before simulation state is applied.
- Pre Solver:
Executed during the time step before the simulation is updated.
- Post Solver:
Executed during the time step after the simulation is updated.
- Custom:
Named effector stage for custom solver builds. This is not used by the XPBD simulation Nodes but is intended for experimentation.
- Geometry Effector Geometry
Closure that is used with Geometry type effectors. The closure has a Geometry input and output that can be modified by the effector. It also has a To World Transform input which transforms from simulation space to world space.
- World Effector World
Closure that is used with World type effectors. The closure has a World bundle input and output that can be modified by the effector. It also has a To World Transform input which transforms from simulation space to world space.
- Filter Geometry
Optional comma-separated list of filter tags to limit the geometries that effector is applied to. Only geometries with at least one matching tag will be processed by the effector.
Uscite¶
- Effector
Resulting effector bundle. This should be stored in the simulation world.
