Vector Curves Node¶
The Vector Curves node maps an input vector components to a curve.
Use this curve node to slow things down or speed them up from the original scene.
Ingressi¶
In the shader context the node also has an additional Factor property.
- Fattore
Controls the amount of influence the node exerts on the output vector.
- Vector
Standard vector input.
Proprietà¶
- Canale
X, Y, Z
- Curva
For the curve controls see: Curve widget.
Uscite¶
- Vector
Standard vector output.
