Is Edge Smooth Node
Is Edge Smooth Node.
The Is Edge Smooth node outputs true for each edge of the mesh that is not marked as sharp. Otherwise, if the edge is marked as sharp, then the node outputs false.
Ingressi
Uscite
Smooth
Boolean value that indicates whether the edges of the mesh are not marked as sharp.
