Nodo Imagen para bokeh#
The Bokeh Image node generates a special input image for use with the Bokeh Blur filter node.
The Bokeh Image node is designed to create a reference image which simulates optical parameters such as aperture shape and lens distortions which have important impacts on bokeh in real cameras.
Entradas#
Este nodo no contiene conectores de entrada.
Propiedades#
The first three settings simulate the aperture of the camera.
- Aletas
Sets an integer number of blades for the cameras iris diaphragm.
- Ángulo
Gives these blades an angular offset relative to the image plane.
- Redondeado
Sets the curvature of the blades with (0 to 1) from straight to bringing them to a perfect circle.
- Catadióptrico
Provides a type of distortion found in mirror lenses and some telescopes. This can be useful to produce a visual complex bokeh.
- Desplazamiento de lente
Introduces chromatic aberration into the blur such as would be caused by a tilt-shift lens.
Salidas#
- Imagen
The generated bokeh image.
Ejemplo#
In the example below the Bokeh Image is used to define the shape of the bokeh for the Bokeh Blur node.
Example of Bokeh Image node.#
