Edge Paths to Selection Node
Edge Paths to Selection Node.
The Edge Paths to Selection node follows paths across mesh edges and outputs a selection of every visited edge.
Veja também
This node is meant to use the output of the Shortest Edge Paths Node. It can be combined with the Separate Geometry Node to remove any unused edges.
Inputs
Start Vertices
A selection of the vertices to start at when traveling along the next vertex indices.
Next Vertex Index
Describes the path to follow at every vertex.
Saídas
Seleção
A boolean field indicating all edges visited when traversing the mesh.
