Split Edges Node¶
Like the Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking “links” between faces around those split edges.
Inputs¶
- Mesh
Entrada padrão de geometria.
- Seleção
A standard Boolean selection input to determine which edges will be split.
Nota
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Saídas¶
- Mesh
Saída padrão de geometria.
