Vector Curves Node¶
![Vector Curves Node.](../../../../_images/compositing_node-types_CompositorNodeCurveVec.webp)
The Vector Curves node maps an input vector components to a curve.
Use this curve node to slow things down or speed them up from the original scene.
Inputs¶
In the shader context the node also has an additional Factor property.
- Fator
Controls the amount of influence the node exerts on the output vector.
- Vector
Standard vector input.
Properties¶
- Channel
X, Y, Z
- Curve
For the curve controls see: Curve widget.
Saídas¶
- Vector
Standard vector output.
