Mesh Boolean Node
Mesh Boolean node.
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Inputs
Mesh 1/2
Entrada padrão de geometria.
Self Intersection Exact Solver
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Hole Tolerant Exact Solver
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Propriedades
Operação
Intersecção:
Produz uma nova geometria contendo apenas o volume dentro de tanto a geometria 1 e geometria 2.
União:
The two input meshes are joined, then any interior elements are removed.
Diferença:
Geometria 2 é subtraída da geometria 1 (tudo fora da geometria 2 é mantido).
Solucionador
Algorithm used to calculate the Boolean intersections.
Float:
Uses a mathematically simple solver which offers the good performance; however, this solver lacks support for overlapping geometry.
Exact:
Uses a mathematically complex solver which offers the best results when there are coplanar faces or other overlapping geometry; however, this solver is much slower.
Manifold (contíguo(a)):
Uses a solver that is usually fastest but only works on Manifold meshes, (plus the special case of Difference with a plane).
Saída
Mesh
Saída padrão de geometria.
Intersecting Edges Exact Solver
A boolean attribute field with a selection of the edges that were created where the two inputs meet.
