Mesh to Volume Node¶
The Mesh to Volume node creates a fog volumes based on the shape of a mesh.
The volume is created with a grid of the name "density".
Inputs¶
- Mesh
Standard Mesh input.
- Density
Valor de voxels dentro do volume fog gerado.
- Resolution Mode
Como o tamanho do voxel é especificado.
- Quantidade:
Especifica o número aproximado de voxels ao longo da diagonal.
- Tamanho:
Specify the voxel side length. It is recommended to be careful when tweaking this value, because small changes can have a large effect on the processing time.
- Voxel Amount Amount
- Voxel Size Size
Especifica o comprimento do lado do voxel.
- Interior Band Width
The maximum distance of the included voxels to the surface on the inside of the mesh.
Saídas¶
- Volume
The generated volume grid.
