Transform and Project Node
Transform and Project node.
The Transform and Project node transforms a 3D position and projects it into normalized screen coordinates using the given transform and projection matrices.
This is a lower-level version of the 3D to Screen Space node that operates directly on projection data instead of a camera object.
Inputs
Vector
Position to project.
Transformar
Transformation matrix applied before projection.
Projeção
Projection matrix used to project the transformed position.
Saídas
Normalizado
Normalized screen-space coordinates.
A value of (0, 0) corresponds to the bottom-left corner of the projected view and (1, 1) corresponds to the top-right corner.
Profundidade
Depth of the transformed position relative to the projection.
