Mesh to Volume Node
Mesh to Volume node.
The Mesh to Volume node creates a fog volumes based on the shape of a mesh. The volume is created with a grid of the name "density".
入力
Mesh(メッシュ)
Standard Mesh input.
Density(密度)
Value of voxels inside the generated fog volume.
Resolution Mode(解像度モード)
How the voxel size is specified.
Amount(量):
Specify the approximate number of voxels along the diagonal.
Size(サイズ):
Specify the voxel side length. It is recommended to be careful when tweaking this value, because small changes can have a large effect on the processing time.
Voxel Amount Amount
Voxel Size Size
Interior Band Width(内部の幅)
The maximum distance of the included voxels to the surface on the inside of the mesh.
出力
Volume(ボリューム)
The generated volume grid.
