Split Edges Node¶
Like the Edge Split(辺分離)モディファイアー, the Split Edges node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
入力¶
- Mesh(メッシュ)
標準のジオメトリ入力です。
- Selection(選択)
A standard Boolean selection input to determine which edges will be split.
注釈
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
出力¶
- Mesh(メッシュ)
標準のジオメトリ出力です。
