Scale Elements Node
Scale Elements node.
Scales the selected faces or edges, letting you specify a scaling factor and pivot point for each one. Connected faces/edges are scaled together using their average factor and pivot point.
入力
Geometry(ジオメトリ)
標準のジオメトリ入力です。
Selection(選択)
Boolean field indicating which elements to scale.
Scale(スケール)
The scaling factor for each element.
Center(中心)
The pivot point for each element.
Axis Single Axis Mode Only
Axis along which to scale each element. This vector is normalized internally, so the length does not matter.
Scale Mode
Uniform(均一):
Scale elements by the same factor in every direction.
Single Axis:
Scale elements in a single direction defined by the Axis input.
Properties(プロパティ)
Domain(ドメイン)
The element type to transform.
Face(面):
Scale faces.
Edge(辺):
Scale edges.
Output(出力)
Geometry(ジオメトリ)
標準のジオメトリ出力です。
../../../../_images/modeling_geometry-nodes_flip-faces_extrude.png
The node is useful when combined with the Extrude Mesh Node, especially in Individual mode where connected faces aren't extruded together.
