Separate Spherical Node¶
The Separate Spherical node converts a vector from Cartesian coordinates (X, Y, Z) into spherical coordinates (R, Φ, Θ) and outputs each component separately. It is the inverse of the Combine Spherical node.
Spherical coordinates describe a position in 3D space using radius, azimuth (horizontal angle), and polar (vertical) angle. This representation is useful for procedural effects involving rotational symmetry, spherical gradients, or direction-based transformations.
入力¶
- Vector(ベクトル)
The input Cartesian vector to be converted into spherical coordinates.
出力¶
- R
The radial distance from the origin.
- Phi
The azimuthal angle (horizontal rotation) around the Z axis, measured in radians.
- Theta
The polar angle (vertical inclination) from the Z axis, measured in radians.
