Transform and Project Node¶
The Transform and Project node transforms a 3D position and projects it into normalized screen coordinates using the given transform and projection matrices.
This is a lower-level version of the 3D to Screen Space node that operates directly on projection data instead of a camera object.
入力¶
- Vector(ベクトル)
Position to project.
- Transform(トランスフォーム)
Transformation matrix applied before projection.
- Projection (投影)
Projection matrix used to project the transformed position.
出力¶
- Normalized(正規化)
Normalized screen-space coordinates.
A value of
(0, 0)corresponds to the bottom-left corner of the projected view and(1, 1)corresponds to the top-right corner.- Depth(深度)
Depth of the transformed position relative to the projection.
