Combine Cylindrical Node¶
The Combine Cylindrical node converts cylindrical coordinates (R, Φ, Z) into a Cartesian vector (X, Y, Z). It is the inverse of the Separate Cylindrical node.
This node is useful for constructing positions or directions based on radial distance, rotation angle, and height, such as creating spiral shapes or cylindrical displacements.
Đầu Vào (Inputs)¶
- R
The radial distance from the origin in the X-Y plane.
- Phi
The angle around the Z axis.
- Z
The vertical position or height component.
Đầu Ra (Outputs)¶
- Véctơ (Vector)
The resulting Cartesian vector corresponding to the input cylindrical coordinates.
