Nodo Intercambiar (identificador)¶
The Index Switch node outputs one of its inputs based on an integer Index value. Only the selected input is evaluated, making this node useful for switching between multiple data inputs efficiently.
Ver también
The Menu Switch node provides similar functionality, but exposes the selection as a user-friendly menu rather than an index.
Entradas¶
- Identificador
Determines which of the following input sockets is passed through to the output. The index is zero-based (i.e., the first input corresponds to index 0).
Each socket represents a possible input to select from. The active input is determined by the Index value.
Additional input sockets can be added by either: - Dragging a connection onto the empty socket at the bottom of the list. - Clicking the icon in the node header.
Truco
When the Index input is connected to a Menu Switch node set to Integer Type, the corresponding menu labels will automatically be shown next to the index value. This provides a clearer context for what each numeric index represents, making node networks more readable.
Propiedades¶
- Tipo
Determines the type of the data that is handled by the node.
Salidas¶
- Salida
Outputs the value from the input corresponding to the current Index value, without any modification. If the Index value is outside the range of available inputs, the output defaults to the first input or a zero-equivalent value, depending on the data type.
