Project with Depth Node
Project with Depth node.
The Project with Depth node reconstructs a 3D position from normalized screen coordinates and a depth value using the given transform and projection matrices.
This is a lower-level version of the Screen Space to 3D node that operates directly on projection data instead of a camera object.
Entradas
Normalizar
Normalized screen-space coordinates.
A value of (0, 0) corresponds to the bottom-left corner of the projected view and (1, 1) corresponds to the top-right corner.
Profundidad
Depth of the point relative to the projection.
Proyección
Projection matrix used to reconstruct the position.
Transformación
Transformation matrix applied after reconstructing the position.
Clip Start
Near clipping distance used by the projection.
Clip End
Far clipping distance used by the projection.
Salidas
Vector
Reconstructed 3D position.
