Vector Rotate Node
The Vector Rotate Node provides the ability to rotate a vector around a pivot point (Center).
Entradas
- Vector
Vector to be rotated.
- Centro
Point to rotate around.
- Eje
Axis to rotate around.
- Ángulo
Angle to rotate the input vector by.
- Rotación
When Type is set to Euler, rotate the input vector by these angles around the X, Y, then Z axes in that order.
Propiedades
- Tipo
The type of angle input.
- X/Y/Z Axis:
Rotates the vector around the defined axis and the amount of rotation is defined by the Angle input.
- Eje y Ángulo:
Rotates the vector around an arbitrary axis defined by the Axis input vector. The amount of rotation is defined by the Angle input.
- Euler:
Rotates the vector about a center point defined by the Center input vector. The amount of rotation on each axis is defined by the Rotation input vector.
- Invertir
Inverts the rotation angle.
Salidas
- Vector
The rotated vector.
Ejemplos
Vector Rotate node example.
