Nodo Booleana (malla)
El nodo Booleana (malla).
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Entradas
Malla 1/2
Entrada estándar de geometría.
Intersección propia método Exacto
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Tolerancia a huecos método Exacto
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Propiedades
Operación
Intersección:
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
Unión:
The two input meshes are joined, then any interior elements are removed.
Diferencia:
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Método de resolución
Algoritmo utilizado para calcular las intersecciones booleanas.
Decimal:
Uses a mathematically simple solver which offers the good performance; however, this solver lacks support for overlapping geometry.
Exacto:
Uses a mathematically complex solver which offers the best results when there are coplanar faces or other overlapping geometry; however, this solver is much slower.
Desplegable:
Uses a solver that is usually fastest but only works on Manifold meshes, (plus the special case of Difference with a plane).
Salida
Malla
Salida estándar de geometría.
Bordes intersectados método Exacto
A boolean attribute field with a selection of the edges that were created where the two inputs meet.
