Nodo Malla a puntos¶
The Mesh to Points node generates a point cloud from a mesh.
Entradas¶
- Malla
Entrada estándar de malla.
- Selección
The meshes used to generate a point cloud.
- Posición
Positions of generated points. By default, this input is the same as if the Nodo Posición was connected.
- Radio
Radios de los puntos generados.
Propiedades¶
- Modo
- Vértices:
Points are generated for each vertex.
- Bordes:
Points are generated for each edge, at the middle of each edge, by default.
- Caras:
Points are generated for each face, at the average of all of each face’s vertices, by default.
- Esquinas:
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Salidas¶
- Puntos
Nube de puntos generada.
