Edge Length Node¶
The Edge Length node outputs the length of each edge in a mesh. It calculates the distance between the two vertices that define each edge.
This node can be used for geometric analysis, mesh-based effects, or procedural operations that depend on edge length (such as adaptive subdivision, weight mapping, or trimming).
Inputs – Уводи¶
Цей вузол не має уводів.
Outputs – Виводи¶
- Довжина – Length
The length of each edge as a floating-point value, measured in the same units as the scene scale.
