Split Edges Node¶
Like the Модифікатор «Розділ Ребром» – Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking „links“ between faces around those split edges.
Inputs – Уводи¶
- Mesh – Сіть
Standard geometry input.
- Виділення
A standard Boolean selection input to determine which edges will be split.
Примітка
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Outputs – Виводи¶
- Mesh – Сіть
Standard geometry output.
