Edge Neighbors Node
Edge Neighbors Node.
The Edge Neighbors node outputs topology information relating to each edge of a mesh.
Inputs – Уводи
Цей вузол не має уводів.
Outputs – Виводи
Face Count
The number of faces that use the edge as one of their sides. When the value is one, the edge is a non-manifold boundary edge. Alternatively, when the value is zero, the edge is a loose edge, not used by any faces.
Examples – Приклади
../../../../_images/modeling_geometry-nodes_input_edge-vertices_boundary.png
Using the Face Count output to create a curve on a mesh’s boundary edges.
