Mesh to Points Node
Mesh to Points node.
The Mesh to Points node generates a point cloud from a mesh.
Inputs – Уводи
Mesh – Сіть
Standard Mesh input.
Виділення
The meshes used to generate a point cloud.
Position – Позиція
Positions of generated points. By default, this input is the same as if the Position Node was connected.
Radius – Радіус
Radii of generated points.
Властивості
Режим
Vertices – Вершини:
Points are generated for each vertex.
Edges – Краї:
Points are generated for each edge, at the middle of each edge, by default.
Обличчя:
Points are generated for each face, at the average of all of each face’s vertices, by default.
Corners – Кутки:
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Outputs – Виводи
Points – Точки
Generated point cloud.
