Mesh to Curve Node
Mesh to Curve node.
The Mesh to Curve node converts a mesh into one or more curve splines.
Two different conversion modes are supported, depending on the desired output:
  • Edges: Turns each string of connected mesh edges into a poly spline. Whenever two or more edge strings intersect, they will be split into separate splines.
  • Faces: Creates a cyclic spline from each mesh face. This mode is generally much faster than Edges, as it parallelizes easily and can share face and corner attributes without needing to copy them.
Loose vertices are ignored – they will not be turned into single-point splines.
Attributes, both named and unnamed ones, are transferred to the resulting splines. If there is a radius attribute, it will be applied as such, although you may find it more convenient to use the Set Curve Radius Node for this.
Inputs – Уводи
Mesh – Сіть
Standard mesh input.
Selection – Вибрання
A field input evaluated on the edge domain to determine whether each edge will be included in the result.
Порада
Using this input is more efficient than deleting parts of the geometry before or after the conversion.
Properties – Властивості
Mode – Режим
Determines how the mesh is converted to curves:
Edges – Краї:
Converts connected edge chains into poly splines.
Faces – Грані:
Converts each face into a cyclic spline.
Outputs – Виводи
Curve – Крива
Generated curve.
