Face Neighbors Node
Face Neighbors Node.
The Face Neighbors node outputs topology information relating to each face of a mesh.
Inputs – Уводи
Цей вузол не має уводів.
Outputs – Виводи
Vertex Count
This output is simply the number of sides of each face, or how many corners each face has.
Neighboring Face Count
The number of faces that connect to this face with at least one edge. On a regular manifold mesh with only quads and triangles, this will be the same as the vertex count, otherwise it might be completely different.
