Scale Elements Node
Scale Elements node.
Scales the selected faces or edges, letting you specify a scaling factor and pivot point for each one. Connected faces/edges are scaled together using their average factor and pivot point.
Inputs – Уводи
Геометрія
Standard geometry input.
Виділення
Boolean field indicating which elements to scale.
Масштаб
The scaling factor for each element.
Center – Центр
The pivot point for each element.
Axis Single Axis Mode Only
Axis along which to scale each element. This vector is normalized internally, so the length does not matter.
Scale Mode – Режим Масштабу
Uniform – Рівномірно:
Scale elements by the same factor in every direction.
Single Axis – Одинична Вісь:
Scale elements in a single direction defined by the Axis input.
Властивості
Домен – Domain
The element type to transform.
Обличчя:
Scale faces.
Край:
Scale edges.
Вивід – Output
Геометрія
Standard geometry output.
Examples – Приклади
../../../../_images/modeling_geometry-nodes_flip-faces_extrude.png
The node is useful when combined with the Extrude Mesh Node, especially in Individual mode where connected faces aren’t extruded together.
