Mesh Boolean Node
Mesh Boolean node.
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Inputs – Уводи
Mesh 1/2
Standard geometry input.
Self Intersection Exact Solver
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Hole Tolerant Exact Solver
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Властивості
Operation – Операція
Intersect – Перетин:
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
Union – Об’єднання:
The two input meshes are joined, then any interior elements are removed.
Difference – Різниця:
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Solver – Рішач
Algorithm used to calculate the Boolean intersections.
Float:
Uses a mathematically simple solver which offers the good performance; however, this solver lacks support for overlapping geometry.
Exact:
Uses a mathematically complex solver which offers the best results when there are coplanar faces or other overlapping geometry; however, this solver is much slower.
Manifold – Розгортне:
Uses a solver that is usually fastest but only works on Manifold meshes, (plus the special case of Difference with a plane).
Вивід – Output
Mesh – Сіть
Standard geometry output.
Intersecting Edges Exact Solver
A boolean attribute field with a selection of the edges that were created where the two inputs meet.
