Is Edge Loose Node
Is Edge Loose Node.
The Is Edge Loose node outputs a boolean value indicating whether each edge in a mesh is loose. A loose edge is not connected to any faces, meaning it exists independently of the mesh surface.
This node can be used to detect or isolate wireframe elements, stray geometry, or edges intentionally used for guides or supports.
Inputs – Уводи
Цей вузол не має уводів.
Outputs – Виводи
Is Edge Loose
Boolean value that indicates whether each edge is loose. True if the edge is not connected to any faces; false otherwise.
