Subdivision Surface Node
Subdivision Surface Node.
The Subdivision Surface node adds new faces to mesh geometry using a Catmull-Clark subdivision method.
Inputs – Уводи
Mesh – Сіть
Standard geometry input.
Level – Рівень
The number of subdivisions to apply to the input geometry.
Складка на Ребрі – Edge Crease
Controls how smooth edges should be with Виважені Складки на Ребрах – Weighted Edge Creases.
Vertex Crease
Controls how much the subdivision surface should be pulled towards the vertex. Similar to edge creases, but allows individual vertices to be creased.
Limit Surface
Places vertices at the surface that would be produced with infinite levels of subdivision (smoothest possible shape).
Згладження UV – UV Smooth
Controls how subdivision smoothing is applied to UVs.
Нічого:
UVs remain unchanged.
Keep Corners:
UV islands are smoothed, but their boundary remain unchanged.
Keep Corners, Junctions:
UVs are smoothed, corners on discontinuous boundary and junctions of three or more regions are kept sharp.
Keep Corners, Junctions, Concave:
UVs are smoothed, corners on discontinuous boundary, junctions of three or more regions and darts and concave corners are kept sharp.
Keep Boundaries:
UVs are smoothed, boundaries are kept sharp.
All – Усе:
UVs and their boundaries are smoothed.
Boundary Smooth
Controls how open boundaries (and corners) are smoothed.
All – Усе:
Smooth boundaries, including corners.
Keep Corners:
Smooth boundaries, but corners are kept sharp.
Outputs – Виводи
Mesh – Сіть
Standard geometry output.
