Face Corner Angle Node¶
The Face Corner Angle node outputs geometric information about the angle at each face corner of a mesh. It can be used to analyze the shape of polygons, detect sharp corners, or create procedural effects based on corner geometry.
Inputs – Уводи¶
Цей вузол не має уводів.
Outputs – Виводи¶
- Кут Кутка – Corner Angle
The internal angle at each face corner, measured in radians. For example, a right angle returns approximately
1.571.- Bisector
A normalized vector pointing along the bisector of the corner angle, halfway between the directions of the two connected edges.
